August 29, 2023 at 3:32 pm
The piston is what drives both the power piston and the displacer. Hence the crank pushes the power piston into the cylinder.
Once the flywheel turns the displacer moves to the heated zone and the air is compressed by a heat source. The displacer then shuttles the air back to the cooler zone.
Do i need to specify the temperatures of the cold side and hot side or can this be done within ansys.
This is seeming to be challenging
