August 30, 2023 at 6:41 am
Hi Peter, thank you very much for the inputs. I could reproduce the moment graph as shown by you by changing the substeps.
I also noticed that the direction of joint probe force is changing along with platform orientation because ANSYS is reporting the force in joint reference coordinate system (which is rotating) and not in global coordinate system.
And Joint Load - Rotational Velocity and Joint Load - Rotational Acceleration could be given only in Transient Structural and not in Static Structural.
Thank you once again.
