Akshay Panchwagh
Hello mjmiddle,
I tried to use a modified version of this script to save the tabular results in a CSV file for a Parameter Set I am evaluating. However, when I try to update the Design Points through Workbench, the script does not work at all. Only when I manually run the simulations through Mechanical does the script store results in a CSV file. I have written the script in a Python Code Object. Can you please let me know what might be going worng? I have been stuck on this issue for many days now. I need to extract these results since I need the temperature values for all the time steps (I am performing transient thermal simuations).
For your reference, I am sharing the script that I am using for my use-case. The Property Provider has been modified to include the Design Point number as a Parameter.
def after_post(this, solution):# Do not edit this line
    Called after post processing.
    Keyword Arguments :
        this -- the datamodel object instance of the python code object you are currently editing in the tree
        solution -- Solution
    # User Dir
    import os
    import csv
    import wbjn
    UserDir = os.path.dirname(ExtAPI.DataModel.AnalysisList[0].WorkingDir) + "\..\..\..\user_files\\"
    # DPValue as parameter
    DPValue = this.GetCustomPropertyByPath("Parameter/DPValue").Value
    dpn = "DP_"+str(int(DPValue))
    def writeCSV(filename, data):
    #Function to write python list to a csv file
        with open(filename, 'wb') as csvfile:
            spamwriter = csv.writer(csvfile, delimiter=';', quotechar='|', quoting=csv.QUOTE_MINIMAL)
            for row in data:
                spamwriter.writerow(row)
    ResultsOfInterest = []
    ResultsOfInterest.append(ExtAPI.DataModel.AnalysisList[0].Solution.Children[1].Name)
    ResultsOfInterest.append(ExtAPI.DataModel.AnalysisList[0].Solution.Children[2].Name)
    ResultsOfInterest.append(ExtAPI.DataModel.AnalysisList[0].Solution.Children[3].Name)
    ResultsOfInterest.append(ExtAPI.DataModel.AnalysisList[0].Solution.Children[4].Name)
    cmd = 'returnValue(GetUserFilesDirectory())'
    user_dir = wbjn.ExecuteCommand(ExtAPI, cmd)
    solution=ExtAPI.DataModel.AnalysisList[0].Solution
    for j, item in enumerate(solution.Children):
        if item.GetType() == Ansys.ACT.Automation.Mechanical.Results.ThermalResults.TemperatureResult:
            if item.Name in ResultsOfInterest:
                item.Activate()
                data=[]
                del data[:]
                Pane=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData)
                Con = Pane.ControlUnknown
                for R in range(1,Con.RowsCount+1):
                    data.append([])
                    for C in range(2,Con.ColumnsCount+1):
                        data[-1].append(Con.cell(R,C).Text)
                    writeCSV(user_dir + "/" + Model.Analyses[0].Name + " - " + item.Name +dpn+ ".csv", data)
    pass
This script was originally written by one Pat Tessaro of Ozen Engineering Inc. I have modified the script which I found on their blogpost.
