Maks Brus
Greetings Akshay!
Sadly I have not found a solution to this problem. The way I went about my research was to reduce the number of iterations to a managable amount, and then to manually export the data. A suboptimal path, but I had a limited time frame.
Hopefully you will find a way to do this automatically, as I noted in the original post this seems as something that should be included in the program. If you do manage to solve this, please inform me as I would like to know how to automate this in the future.
Best of luck
Maks
