August 30, 2023 at 5:31 pm
Hi Mike,
That is quite reassuring to know that the code worked. Even in my case the Target Callback is set to "After Post". I wonder what is going wrong. The above code was written between "def after_post(this, solution)" and "pass".
Tomorrow I will look into it again and provide an update.
P.S.: Did you update your Design Points through Workbench without opening Mechanical? I read somewhere today that apparantly some commands in this code need the Mechanical GUI running. Outside the Mechanical GUI they do not work. Hence I just wanted to clarify it.
Akshay
