Weihan Lin
Hi Akshay,
Thanks for the reply. Here are the error messages I found in the solution information page. Let me know if it helps or no. It seems that my contact regions has some problem, but I don't know why this happened. If I change the rubber thickness from 1/16 inch to 2 inches, there's no error.
*** ERROR ***                           CP =       3.891   TIME= 16:56:20
 Element 10417 has excessive thickness change.
 *** LOAD STEP     1   SUBSTEP     1  NOT COMPLETED.  CUM ITER =      2
 *** BEGIN BISECTION NUMBER   1    NEW TIME INCREMENT=   7.0000
 *** NOTE ***                            CP =       3.891   TIME= 16:56:20
 Predictor is ON by default for structural elements with rotational
 degrees of freedom.  Use the PRED,OFF command to turn the predictor
 OFF if it adversely affects the convergence.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          28
 *** NOTE ***                            CP =       4.969   TIME= 16:56:21
 Contact pair is inactive.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          29
 No contact was detected.
 Max.  Pinball distance 6.093701855E-03.
 One of the contact searching regions contains at least 8 target
 elements.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          30
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          31
 elements.
One of the contact searching regions contains at least 220 target
 elements.  You may reduce the pinball radius (current value
 9.972265941E-03) for contact pair identified by real constant set 40
 to speed up contact searching.
 Range of element maximum matrix coefficients in global coordinates
 Maximum = 6781141.29 at element 16858.
 Minimum = 12160.5806 at element 8110.
     FORCE CONVERGENCE VALUE  =   1.634      CRITERION=  0.8334E-02
     MOMENT CONVERGENCE VALUE =  0.3343E-12  CRITERION=  0.5102E-04
 SPARSE MATRIX DIRECT SOLVER.
  Number of equations =       97485,    Maximum wavefront =     60
  Memory allocated for solver              =   312.443 MB
  Memory required for in-core solution     =   299.944 MB
  Memory required for out-of-core solution =   116.053 MB
 *** NOTE ***                            CP =       5.234   TIME= 16:56:21
 The Sparse Matrix Solver is currently running in the in-core memory
 mode.  This memory mode uses the most amount of memory in order to
 avoid using the hard drive as much as possible, which most often
 results in the fastest solution time.  This mode is recommended if
 enough physical memory is present to accommodate all of the solver
 data.
 curEqn=  84522  totEqn=  97485 Job CP sec=      5.562
      Factor Done=  68% Factor Wall sec=      0.000 rate=       0.0 GFlops
 curEqn=  97485  totEqn=  97485 Job CP sec=      5.578
      Factor Done= 100% Factor Wall sec=      0.030 rate=     424.3 GFlops
 Sparse solver maximum pivot= 9636186.61 at node 1650 UY.
 Sparse solver minimum pivot= 1.425333714E-04 at node 7549 ROTY.
 Sparse solver minimum pivot in absolute value= 1.425333714E-04 at node
 7549 ROTY.
     DISP CONVERGENCE VALUE   =   8.242      CRITERION=  0.4205
    EQUIL ITER   1 COMPLETED.  NEW TRIANG MATRIX.  MAX DOF INC=   22.82
