Yunpeng Wu
  1. When I tried to do a max angle of 155 degrees, the command didn't drive the remesh, even 100 degrees, the remesh can't happens, and the maxium to start the remesh is 90 degree.
  2. This structure is a plane, 100*100 elements, and each element is a 1*1 square, when I use the same material for all the elements, it can converge without remesh, but if I choose to use 2 different materials, the non-linear process can't converge.
Do you have any idea about why this problem happens?
The code is shown below:
FINISH
/CLEAR
*do,fid,1,1
/PREP7
!=== Define material 1
ET,1,PLANE182
MP,EX,1,2000
MP,PRXY,1,0.3
!==== Define material 2
ET,2,PLANE182
MP,EX,2,1000
MP,PRXY,2,0.3
/PREP7
NDELE,ALL
EDELE,ALL
DDELE,ALL,ALL
NUMCMP,ALL
!NLADAPTIVE,ALL,ADD,MESH,SKEWNESS,0.9
*set,ntb
*set,etb
filename=strcat('nodes',chrval(fid))
fext='dat'
/INQUIRE,rows1,LINES,%filename%,%fext%
*DIM,ntb,ARRAY,rows1,4
*VREAD,ntb,%filename%,%fext%,,JIK,4,rows1
(4F6.0)    !* read 4 real numbers with maximum 6 digits, use 6 if number is 10000
filename=strcat('elements',chrval(fid))
/INQUIRE,rows2,LINES,%filename%,%fext%
*DIM,etb,ARRAY,rows2,5
*VREAD,etb,%filename%,%fext%,,JIK,5,rows2
(5F6.0)
*do,i,1,rows1
    n,ntb(i,1),ntb(i,2),ntb(i,3),ntb(i,4)
*enddo
*do,i,1,rows2
    e,etb(i,1),etb(i,2),etb(i,3),etb(i,4)
*enddo
!=== Define element group 1
k=0
nElements=1
*do,i,1,rows2
    nElements=nElements+1
       *if,etb(i,5),eq,1,then
              k=k+1
       *endif
*enddo
*status,k
*status,nElements
ESEL,S,elem,,1,k
MPCHG,1,ALL
CM,MATRIX,ELEM
ESEL,S,ELEM,,k+1,nElements
MPCHG,2,ALL
CM,FILLER,ELEM
/SOL
ANTYPE,0,NEW
NLGEOM,1
NSUBST,1000,2000,10
AUTOTS,-1.0
ALLSEL,ALL
NSEL,S,LOC,X,0
D,ALL,UX,0
NSEL,S,LOC,Y,0
D,ALL,UY,0
NSEL,S,LOC,Y,100
CP,NEXT,UY,ALL
ALLSEL,ALL
filename=strcat('nlist',chrval(fid))
/INQUIRE,rows3,LINES,%filename%,%fext%
*DIM,ctb,ARRAY,rows3,3
*VREAD,ctb,%filename%,%fext%,,JIK,3,rows3
(3F6.0)
!=== couple top and bottom nodes for UX
*do,i,1,rows3
    CP,NEXT,UX,ctb(i,2),ctb(i,3)
*enddo
*do,i,1,1     !* loop over three displacements
/SOL
u=100*i
NSEL,S,LOC,X,100
D,ALL,UX,u
ANTYPE,0
NLGEOM,1
!AUTOTS,ON
!DTIME,0.01,0.00001,0.1
!ARCLEN,ON
NSUBST,1000,2000,10
NLADAPTIVE,ALL,ADD,MESH,SHAPE,155
NLMESH,BDRA,50
!CUTCONTROL,DSPLIMIT,10e7
ALLSEL,ALL
SOLVE
FINISH
/POST1
PLDISP,1
NSEL,S,LOC,X,0
set,LAST
fsum
*get,fsum,FSUM,0,ITEM,Fx
force=fsum
filename=strcat('res',chrval(fid))
*if,i,eq,1,then
    *cfopen,%filename%,txt,,
*else
    *cfopen,%filename%,txt,,APPEND
*endif
*vwrite,u,force
(G16.8,G16.8)
*cfclose
tempname=strcat(chrval(fid),'-')
tempname=strcat(tempname,chrval(i))
filename=strcat('nodal_stress_x',tempname)
*do,xid,1,rows1
*set,strx
*GET,strx, node,xid,s,X
*vwrite,strx
(G16.8)
*enddo
*cfclose
filename=strcat('nodal_stress_y',tempname)
*do,xid,1,rows1
*set,stry
*GET,stry, node,xid,s,Y
*vwrite,stry
(G16.8)
*enddo
*cfclose
filename=strcat('nodal_stress_xy',tempname)
*do,xid,1,rows1
*set,strxy
*GET,strxy, node,xid,s,XY
*vwrite,strxy
(G16.8)
*enddo
*cfclose
FINISH
*enddo
/CLEAR
*enddo   !* end of outer loop
