August 31, 2023 at 12:38 am
Hello Jim, I got an Error termination with the same element deletion, however, it works for 63 time steps for the first time, and this is just significant progress. I found that the ALE coupling was the source of error. So, I tweaked some parameters such as the number of coupling points.
I still need to figure out the issue that causes the termination right after the explosive charge is detonated.
