chenglong lee
I have encountered the same problem. Could you please help me solve it, Mike? Thank you.
Using the method you provided, I successfully calculated both the frequency domain and time domain. I need to output the torque at 18 articulated axes, and 16 of them have successfully outputted curves, while 2 have reported errors as follows: E!SC_PLS – KEY NUMBER 4 NOT FOUND#2:KEY=REACTION AT ARTIC 1, Error reading from PLT file, error code: -3. Can you help me solve this problem? I encountered the same issue when using both 2020.R1 and 2021.R2 for calculations.
