Federico Alzamora Previtali
If you click on Mesh Scale Info, you will get a new window which reports the actual scales of your mesh. Use the reported minimum as the Minimum Length scale, and reported maximum as the maximum. This should help with remeshing to keep a similar distribution as you have initially.
