In theory you could make a mesh with a lower y size and have an aspect ratio of 1. Set upper & lower edges as symmetry and you have the domain you want. The problem will be getting the fuel & oxident to mix with a layer of combustion products potentially separating the two. So, in practice it may not work well.
