Keyur Kanade
First create simple 2 curves in DM and try to use Skin tool and check how it works. That will give you idea about it. If you have imported curves and from image it looks like the cuve is in the loop. Split that curve into 2 or 3 curves and then use Skin tool. You can also try SpaceClaim.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
