Suresh Varma
hello erik,
My setup with frictionless contact and behaviour of asymmetric and rest values to program controlled is running when i have both the bodies with the same material which is structural steel and i am obtaining results but when i input glass the analysis goes on but doesn't give me results.
I have tried using increasing stiffness to higher values when i look into solver output it shows too much penetration at xx elements.
Any suggestion on this problem.
Thank you
Suresh varma.
