Łukasz Ruba
Thank you very much. I have tried that but I came across a few problems. I declare all local coordinate systems with the same orientatnion as in my other project without partition. Which means that all coordinate systems are without rotation - the same like global coordinate system. I did it to compare reasults between them.
Firstly, using this method I can't use linear mesh:
It only works when I use program controlled mesh generator and it looks like that:
For me it's quite important to have linear mesh because I'm generating the load in Matlab by coordinates on a strip. I set 'Protected' to 'Yes' but it doesn't work too. Is there something which can I do to use linear elements order?
Temperature results are similar in each case:
(Model without partition)
(Model with partition)
But I have a problem with deformation results:
Why both don't work approximately the same? Is it because of different meshes?
Thanks in advance,
Lucas
