September 3, 2023 at 3:36 pm
Yes I have assigned perfect E boundary to ground plate and the metal plate above. The length of the microstrip line along Y-axis is 10mm and along X-axis is 5mm. The width of the metal line above the silicon dioxide substrate is 5.09mm. Height of the substrate is 4mm.
Now, I am getting the error "SOLVER_OUT_OF_MEMORY" error. Ihave tried reducing the number of passes from 6 to 2. But even then I am getting the above memory error
