manelaero2020
Hi @Rob
Effectively the delta t = 0.1 s is the time step, which can be estimated in the case of heat conduct as L^2/ nu with L being the width of the plate (the solid) and nu being the heat transfer diffusivity (lambda / (rho*Cp) ) .
I guess the physical time is equivalent to the transient state time before the solution becomes stationary.
The exponential heat transfer curve can estimate it
The delta t = 5 s is the global time step, and the number of iterations is 5/ 0.1
Thank you a lot
