Ingrid Machecler
you will need to describe a little bit more how you setup your project before launching the run so we can better help you.
It seems like the solve doesn’t even work on your end.
If you have a connection points or a joint, you can extract the force (and other results type) at its location when you look at the graph results.
Kind regards,
Ingrid
#------------------------------ !! Attention !! --------------------------------
I am amending my initial reply as this question is posted in a different thread and is unrelated to the current one.
You can find a more comprehensive reply here:
how to solve error (reading deck 18)in ansys aqwa?
