September 4, 2023 at 10:36 am
Hi Eugenio,
Many thanks for the update. To clarify, did you suppress Outer Floater in Aqwa Workbench, or did you delete it in the geometry editor, i.e. in SpaceClaim/DesignModeler?
It should not make any difference whether the structure is fully submerged or not.
Please can you try adding a new hydrodynamic diffraction/response workflow, with the geometry linked from the previous workflow:
Then try running these fresh analyses to see whether the problem still occurs. It may be worth doing a test before you add in all of the cables etc.
Cheers, Mike
