Mike Pettit
You just need to reduce the Output Step value. This is the time interval between data points in the results file, so for any meaningful output, you will need to set this to (for example) 0.1 sec.
In the Messages window you should find a warning that the Output Step interval is too large. The message suggests that the interval will be correctly automatically, but it seems like this hasn't actually happened in your case. I will try to get this fixed for the next release.
Otherwise, your project configuration looks good to me. Please let me know if you run into any other problems.
Mike
