Are they using the default uniform mesh in FDE? In the file where you can not find the modes, I would suggest you to add a finer mesh in the waveguide region using mesh override and see if you are able to find the modes now. Also, could you please check the material fitting in the Material Explorer and see if both the simulations are using the exact same values of index for each structure?
Amrita
