Swathi V. V.
What is the particle type choosen in the DPM injection settings. If you have choosen droplet, combusting etc, there is an option under material property to specify the vaporization temperature, boiling point etc. The praticles might be evaporating based on this condition. You can make use of inert particle type if this condition matches your requirement.
