Dan Dv
Hello Mark,
The .asol extension is an internal file type, and is not anything that you can open by itself. The .hfss and .aedt file type are actual project files, so those are what you would try to open to see if there are valid results that you could export s-parameters from. Though a .hfss file is a much older form of the project file and it is not always possible to open those in recent version of the Ansys Electronics Desktop, as opposed to .aedt which is our current project file format.
Best regards,
-Dan
