September 6, 2023 at 8:31 pm
I know the exact power for my structure which I obtained from eq1 (both spectral power density and the total power density). In the example I provided, solar irradiation is used in the script in the analysis group to obtain absorbed power and generation rate which are imported into the charge solver for further analysis.
For my case, is there away I can import spectral flux I obtained into the analysis group instead of using solar irradiation?
Thanks
