Apologies for the late reply.
First, you should not need to start the server manually on the Linux, ceistart will take care of that.
Second, can you try to toggle on the SSH tunneling option and see if that changes the situation?
Can you check on the Linux machine if you see some process starting up?
Thanks,
Marina
