September 7, 2023 at 1:55 pm
I do not have 1000+ different materials, I only have 2 different materials. But I want to parametrize each object for either assigning or not assigning a certain material to it, and use optimetrics to utilize parallel simulation, for an emag topology optimization.
I also realized even if I assign materials with a for loop, there is a bigger problem. Optimetrics is not good at handling the 1000+ parameter sweep. The simulation slows a lot, I assume due to reading a lot of the variables.
I am not sure if there is any other easier way to do it on pyaedt?
