Sebastian,
Use SpaceClaim to split the body instead of just the faces. You will end up with 4 bodies. On the Workbench tab, use the Share button. That will create shared topology. In Mechanical, select the ends to mesh first and they should automatically get a hex mesh. Then mesh the center body and it will get pyramid and tet elements that share nodes at the split planes. No contacts will be created.
