Nikhil Narale
Glad you figured that out. There's also a workaround. If you've already assigned named selections to the car surfaces, when creating the enclosure, select the 'Create shared topology' option under Options-Enclosure. This will create and assign an equivalent named selection on the similar enclosure surface.
