Hello byeongwoo yoo,
In your description you mentioned “there is a conduction loop against the vacuum”. If you want to apply an excitation on an object the material assigned to it needs to be conductive, for example copper, etc.
Please also check that the object is touching the surface of the “Region”.
I hope this helps. Ivonne
