Devendra Badgujar
Forum Moderator
Hello Marin,
It is not possible to check the number of iterations when the solution will stop directly, when we define the monitors we can check solution progression and once it reaches the maximum iterations settings of 300, it will stop and you will get a warning message in the notifications mentioning the particular constraint has not met.
Ansys Discovery also provides you an informational messages indicating partcilar constraint might not be correct and will be auto-updated as per the requirement to solve.
Let me know if you have any further questions on this.
Devendra
