Just adding a comment as I've been away.
If you constrict the domain too much (as you did initially) then the results are as much a result of the modelled region as the bit you're interested in. There are some wind tunnel size guidelines somewhere that explain the phenomena, basically, the object needs to be much smaller than the overall domain.
