How did you initialise the model? If the rotor speed doesn't link to the flow very well then you'll see flow separation and all sorts of weird effects. I still don't understand if you're using sliding mesh with the 6DOF solver to calculate the speed of rotation or if you're remeshing the domain.
To add, 9MPa is a fairly high pressure change, what is the working fluid?
