Andrew Walsten
Hi Faezeh,
Thank you. That helped some. I changed the properties to be more similar to the example. I also moved the ferrite material back a little bit so that it wasn't touching the ground plane as that is more similar to my actual experimental setup. The ferrite material now has an organized mageneti field; however, it is just organizing based off of the magnetic field of the SRR. I need it to behave as a permanent magnet. I have attached images showing my material properties for the ferrite and the magnetic bias setup. I believe I have it setup correctly, but are there any obvious errors you see? I want the ferrite "permanent magnet" to have a field in the z+ direction.
