September 12, 2023 at 3:54 am
Autodyn is a commercial software package developed by Ansys Inc. for simulating dynamic events like explosions, impacts, and other complex physical phenomena. It is primarily used in the field of finite element analysis (FEA) and computational fluid dynamics (CFD) geometry dash scratch. However, Autodyn does not have a direct capability for applying axial loads, as it is not specifically designed for static structural analysis.
If you want to simulate axial loading in Autodyn, you would need to approximate the effect by defining the loading conditions in terms of dynamic events, such as an explosion or an impact, depending on the specific scenario you are trying to model.
