Modal transformation matrices, also known as mode shape transformation matrices or eigenvector transformation matrices, are used in structural dynamics to transform a system's coordinates from the physical space to the modal space. They are typically derived through modal analysis, which involves solving the eigenvalue problem of the system's equations of motion. You can choose trap the cat!
