Billie Jollie
The stiffness factor is the ratio of the moment of inertia of a beam or wire's cross section to its length. As you can see The stiffness factor expresses the'resistance to mini crossword bending'. The stiffness, k, of a body is a measure of the resistance to deformation provided by an elastic body.
