DMARATHE
Hi Chi Zhang,
Thanks for posting your query on Ansys Learing Forum !
In HFSS, you can check 'Mesh Statistics' which provides information on Total mesh element count, and some statistical data of generated mesh elements after adaptive passes completes. This data is num tets, min/max edge length, min/max tet volume etc with respect to geometries in the simulation. This information can be geberated from Project Manager, go to Results > Solution Data > click on Mesh Statistics tab
However, I don't this there is an option to get co-ordinates of each mesh node after adapative passes.
You can define near field probes and export fields data as required.
Thanks
