September 13, 2023 at 6:11 pm
Hi Dmarathe,
I've also found the following discussion (How to export the resulting fields of a ANSYS Maxwell3D simulation) that it is possible to achieve what I want to achieve with the "write" output command in the field calculator. I've outputted mag_E using following this. Could you also comment on out to interpret the outputted file (attached screenshot)?
Thanks,
