September 14, 2023 at 3:48 am
Hi Devendra, I am now facing a new issue. I was trying to read some parameters in Discovery from my .iam assembly file, which contains a master sketch .ipt. However, the paremeters are set to read only as shown below. I set parameters setting to "All" instead of "Independent" inside the Import Options. (It did not appear when I set to "Independent").
Any suggestions on this issue? Is it possible to read some parameters from top-down CAD file like this? Thanks.
Best,
Raihan
