If you don't tell air it can change phase then it won't. The only phase change setting will be (barring some extreme conditions)
Water(liquid) to water(gas).
Water(gas) and air(gas) are a species mixture, and assuming you have no reactions or other phase change mechanisms set air isn't going to do anything other than heat up & flow.
