Akshay Maniyar
Hi David,
The problem may be a result of differences in default settings, contact creation, or some other factors between Ansys versions. It is essential to review contact settings and formulations when switching between software versions and ensure they are correctly set up for your specific simulation. You can try to use the MPC formulation with the same pinball radius in both versions and see if you get similar results.
Thanks,
Akshay Maniyar
