September 14, 2023 at 6:03 pm
Your advice was very helpful and thank you! Now I would like to ask if there is an option to set the orientation of an element using a mesh-dependent function (x,y,z)? Using the above method, I get a simplified orientation distribution model:
However, I would like to define the direction of the x-axis consistent with the direction of the normal vector for each mesh element:
Is it possible?
