September 15, 2023 at 8:06 am
Hi Armin, I tried to apply the Rigid Body Constraint but i didn't obtained the expected displacement. I checked also the displacement obtained suppressing the deformable object (so without any contact between the elements) and in that case the displacement was correct. Can this problem be related to the contact between the plane and the object? I used a frictional contact with 0.3 coefficient
Thank you again
