Atharv Joshi
Forum Moderator
Currently its not possible to add combination of shortcut options which will help you with such complex selection. “Ctrl + Rolling the mouse wheel” helps you select internal faces. You can refer to this help document on Power Selecting Objects (ansys.com) which helps selection based on geometric similarities.
Thanks and Regards
Atharv
