September 15, 2023 at 7:12 pm
Hello Raul,
Yes, partially, thanks to Aleksey. The main mistake I was making was _drawing_ an actual electrolyte layer for the Model 4 (unresolved electrolyte). You have to draw cathode to anode as surface to surface, with no gap between them, so, basically, you split the electrolyte between these two layers. Then you make sure to define them as proper boundaries. So there is no electrolyte layer there, just surfaces.
If you keep trying with Model 3, you need to _draw_ electrolyte as a layer.
I hope that helps.
Kind regards,
Victoria
