September 18, 2023 at 9:20 am
Hello everyone. I am doing a one way fluid structure interaction analysis. I want to know how gas flow through a porous media affects the structure holding the porous media. I have imported the temperature and pressure load into static structural from fluent. I want to know how the temperature and pressure load affects the deformation of the structure, however, the deformation is greatly affected by the placement of the fixed support. The structure is supported on its bottom. Is there a way to only view the effect of the applied temperature and pressure load without considering the effect of the fixed support
