Hello Sorena,
The supported MS VS and Intel Fortran versions for R19.0 are the following:
Visual Studio 2012 (including the MS C++ compiler) and Intel FORTRAN 15.0.7 compiler
It appears that you are using different versions which are not supported. In this case, unfortunately we cannot troubleshoot issues that may be a result of using these unsupported software versions. I would suggest to install the supported versions, recompile/link and see if that resolves the issue.
