Hello everyone,
how do I set up the boundary condition to see the deformation at the diameter of the hole in the Example of hanh (February 18, 2020 at 2:04 pm)? If I use a fixed support on the face of the hole in combination with rotational velocity load, the deformation of the hole is blocked and equals zero. Is there any good solution for this?
Thank You very much,
Christian
