September 19, 2023 at 6:35 pm
Jim and Ushnish,
Thanks for your suggestions. SBOPT=5, DEPTH=55 with SOFT=2 had the same results. I have been trying to tweak the contact thickness and stiffness with no luck.
Do I need to tweak both SFSA and SFSB if it's *AUTOMATIC_SINGLE_SURFACE or just SFSB? Same question for SAST and SBST.
What range of values for SFSA/SFSB should I try first? And what percent of the shell thickness should I increase the contact thickness. I don't have a good feeling for what is reasonable and nothing I try seems to be working.
