September 20, 2023 at 2:05 am
Ok sir I will try. Thank you.
Can you give me recommendations for my speeds? I wrote:
>>Thank you. My tool rotates at 26 rad/s and the feed speed is 40 mm/s. I want to test my speeds on this task from LSTK. Can I leave the solution time at 7.5, set the rotation speed to 26 (at a time of 10,000), and set the feed to 40 (at a time of 10,000). Will this be logical for the program?
I also posted screenshots in the second message. What can you say about them (see message above)? Thank you!
