September 20, 2023 at 2:36 pm
Forum Moderator
You may find you're better off using an interpolation file or ASCII type format from File>Export>Solution Data. As others have commented the case and data files are linked, and whilst the data file will contain all of the results it may not contain all of the required information.
File formats are covered here https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/flu_ug/flu_ug_chp_fileformat.html
